Results 1 to 9 of 9
Thread: Need help with alignment
    Regular slwspd3's Avatar
    May 2011
    manassas, va
    164
    Question Need help with alignment
    ok so i daily my slammed 2nd gen. and i over due for an alignment.
    can someone please help with specs.
    like i said i daily it so i need something that will be tire friendly. (im a complete noob on this, so flame me all you want, just help me after wards)
    thanks for your help
    uhm just get your toe fixed and just adjust camber to what you need. thats what i will be doing when i go in for my alignment tomorrow. just fixing toe and seeing my camber numbers
    Addict XCNuse's Avatar
    Feb 2011
    Atlanta, GA
    644
    in-range specs for our cars are beyond what they need to be, so they wouldn't help.
    as brad said, just get your toe fixed, near zero. That's what damages tires the quickest.
    I have yet to see a 3 go wildly out of spec besides camber.
    Heck, back when I dropped my car, only thing out of spec was camber. Front toe was increased negatively, but still within spec.. but fixed that anyways.
    06 Whitewater Pearl build @ mazda3forums.com
    May 2011
    manassas, va
    164
    Cool thanks guts I'll deff look into the toe when I go in.
    So I need to get my toe as close to "0" as possible?
    correct
  6. #6
    Regular TrainWreck's Avatar
    Dec 2011
    Edmonds, WA
    181
    Yeah best to take it to a shop ,like mine except you're acrOSS the country lol, and have them set rear camber and toe, the. Front camber and toe. Thats th order in which they need to be set. If camber is where you want it for the most part, have them equalize it so that your cross-camber is as close to 0 as possible. I.e. -4,-4 =0 on cross camber. That will ensure it drives straight, and also looks perfectly even. if you want exact factory specs let me know and I can look em up at work.
    Another knocker, kIck this game around like soccer!
  7. #7
    Feb 2011
    Atlanta, GA
    644
    Lol actually perfectly 0 toe is what makes a car squirrelly.
    But yeah.. Still want it near zero.
    Otherwise pull out some fishing line and do it yourself! That's how its done.. Machines kinda make it faster though, but racing teams still use the string and ruler method.
  8. #8
    May 2011
    manassas, va
    164
    ok cool im not doing my rear camber yet cause i still havent installed my rear camber arms(i dont how to yet)
  9. #9
    Dec 2011
    Edmonds, WA
    181
    Quote Originally Posted by XCNuse View Post
    Yes, i should've clarified. Thank you. perfect zero on toe on an alignment machine is the exact preset tolerance. Since fwd cars want to pull the front wheels forward, perfect toe is actually slightly negative, creating a straightening affect when in forward gears. Toe does not affect how a car drives unless it is EXTREMELY far out. Toe compensates itself as you drive essentially dragging the edge of the tire . Camber (front) and caster, which is only a front suspension angle will cause a car to pull, drift or like you said get squirlly. Which is a caster issue, too far negative.
