Results 1 to 22 of 22
Thread: 2010 MS3 Fitment
    Default 2010 MS3 Fitment
    New to Mazdas and to fitment, so I have a few questions. I have my eyes on a set of TSW Silverstones they have limited options so I am wondering what I can fit with only a fender roll, not sure if I want to get a pull yet. I am currently lowers on BC Coilovers, tucking the rear slightly, would like to go lower, prefer not to go over -3 rear camber as this is my DD. Here are my options:
    18x9.5 +20 or +40 offset
    18x8 +20 or +40 offset
    I want to stick with the Ecstas as they still have plenty of rubber. (225/40/18) I have no problem with stretching. Any ideas or recommendations. I figured I may have to settle with the 18x8 +40 and use spacers to fine tune.
    you should buy my advans and i'm coming to vegas next month so i could bring them with me
    Got pics?
    Addict UnZipHer's Avatar
    Nov 2010
    Portland, OR
    794
    That is a fantastic idea :-)
    Regular bigblazer87's Avatar
    Aug 2011
    Elk Grove, CA
    352
    You'll have to run spacers with 18x9.5 +40's to clear the strut, and 18x8 +40's are gonna be a little far in the fenders for my tastes. And don't be scared of negative camber, as a moderate amount won't wear out tires quicker... it's incorrect toe that will eat up tires. I honestly think you'd be fine with the 18x9.5 +20's, rolled fenders, and your current tires... just adjust the camber so the tires clear and you'll be fine.
  6. #6
    Thank you bigblazer I want to get as close to the fender as possible, so I will probably go with the 9.5s, if I am going to do this I might as well do it right.
    lex22pearl, I might be interested in your rims if you want to post pics, stats, and price.
  7. #7
    in my sig. those are the advans
  8. #8
    Those are so sex dude, whats the specs?
  9. #9
    Nevermind dude, I found your post in the WTS section.
  10. #10
    should buy them. perfect for a second gen
  11. #11
    I am new to all this, but it is seeming more and more to me like 9.5 is going to require more than a simple fender lip roll.
    Or it will need more if I want to go lower, right?
  12. #12
    to make it look good i suggest a roll, coilovers and dominant eng camber arms. with this setup i didnt have to pull my fenders at all. just a roll and camber but if you dont want a ton of camber you could do a pull.
  13. #13
    Define a ton of camber? -4, 5, 6? I want to stay away from a pull right now, not sure if I am ready to be fully committed to a flush lifestyle.
  14. #14
    Regular rgz's Avatar
    Jan 2011
    Tx
    302
    then don't get 9.5
  15. #15
    around -5 or -6
  16. #16
    Aug 2011
    Elk Grove, CA
    352
    Between -3.5 and -4 up front and -4.5 to -5.5 in the rear... mine are +25 and I've just got rolled fenders and I'm running -3.6 up front and -4.9 in the rear and I clear perfectly fine with just a little rubbing of the sidewall in the rear.
  17. #17
    there is a more accurate answer lol
  18. #18
    Would 19x8.5 +38 be a safer route than +25. Safer meaning less camber/stretch needed.
  19. #19
    Regular DAR's Avatar
    Sep 2011
    Salinas, Ca
    132
    Quote Originally Posted by Akira View Post
    most defiantly by why would you want 19s's go with 18 and at least 9 width
  20. #20
    ^^ my bad I ment 18x9.5 with +38
    Ive been noticing that 18x9.5 fits better than what I ha wanted before (18x10) so it seems that 18x9.5 ither +25 or 38 I will get.
    This weekend I will be installing my coilovers so I'm getting there. Little by little.
  21. #21
    Sep 2011
    Salinas, Ca
    132
    if you are in the process of stancing your car we are holding a group buy for shorter front 135mm springs for the bc coilovers its only 85$ shipped if you are interested
  22. #22
    Thankyou very much but at the moment that is not on my list.
    Thankyou again tho.
