Fixing Rubbing
Hey everyone, I slammed my ms3 on friday on 18x9 +30 Rota Grids with Raceland coilovers(no bumpstops, turned all the way down), and since then have been rubbing pretty badly. My fenders are rolled and pulled a fair amount(fender roller->textbook-> bat handle) but I still rub over bumps and dips, or with multiple people in the car, and I want to fix this. Is camber the solution? I dont have camber arms and my front bolts arent touched.
Any opinions are welcome
Thanks
Regular
Have you shaved your bumper tabs? Do you know where you are rubbing (where all the tire shavings would most likely be)
Not yet, and thats one spot where I know im rubbing. Other than that I get a little bit on the top of the fender because it rubs over dips and such, and when I accelerate.
On the fronts I rub on the fender liners and over bumps and dips
Regular
Take a dremel to those tabs
I ordered some camber arms and ill be shaving my bumper tabs tonight along with deleting my front fender liners, is there any way to avoid rubbing on acceleration?
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
