Page 1 of 5 123 ... LastLast
Results 1 to 30 of 130
Thread: MZ3/MS3 Fitment List
    Dev Administrator evil-98's Avatar
    Nov 2009
    MF
    303
    Default MZ3/MS3 Fitment List
    List fitment specs for MZ3/MS3 here
    ie. Model, Drop, Front or Rear wheel, Rim spec, Tire spec, Drivable?, Fender modification, Notes
    Mazda 3 09 HB, Eibach Sportline, Front wheel, 17x9 +35, 255/40, Not drivable
    Mazda 3 09 HB, Eibach Sportline, Rear wheel, 17x9 +35, 255/40, Drivable with proper fender modifications (roll, pull) and rubbing where the bumper and fender meet in the rear
    Mazda 3 09 HB, Eibach Sportline, Both Wheels, 17x8 +35, 205/40, Drivable, rolled fenders, tire aspect ratio is off
    Mazda 3 09 HB, Eibach Sportline, Both Wheels, 18x8 +45, 225/40, Drivable, rolled fenders, rubbing in front fender linear and where the bumper and fender meet in the rear
    Mazdaspeed 3 09 HB, Eibach Prokit, Both Wheels, 18x8.5 +38, 245/40, Drivable, rolled fenders, rubbing in front fender linear and where the bumper and fender meet in the rear
    Mazdaspeed 3 09 HB, KW Variant 1 coilovers, 18x8.5 +38, 225/40/18, rolled/shaved fenders, rubbing on front fender liner full lock.
    Regular hoygagoka's Avatar
    Dec 2009
    Placentia
    176
    Great thread! Now we need to add Shavi and Amir on the list.
    - Tint - LED kit - GROM Aux Mod - OEM Flip Key - 2.0 Screw-on filter conversion - VG Shark Fin antenna - 08' shift knob - MS3 Shift Boot - LED reverse lights - Volt 35w 6000k HIDs - M3 style trunk lip - Tein S-Techs - HD lip- Injen CAI - Smoked LED 3rd Brake Light- Black 5zigen FN01R-C's - Red Muteki Lugs-
    Nov 2009
    MF
    303
    updated first post with;
    "Mazdaspeed 3 09 HB, Eibach Prokit, Both Wheels, 18x8.5 +38, 245/40, Drivable, rolled fenders, rubbing in front fender linear and where the bumper and fender meet in the rear"
    Regular ihartmyhatchie's Avatar
    Nov 2009
    Bellflower, CA
    359
    I'm honored. BUT I NEEDS MOAR LOWS.
  6. #6
    Administrators SHaW's Avatar
    Nov 2009
    Anaheim Hills, CA
    1,682
    Mazda 3 05 HB, BC Coilovers, 17x8 +25, 17x9 +20, 205/40/17, fenders rolled/shaved, drive-able.
    2009 TRUE RED MazdaSpeed3 GT NAV
  7. #7
    Nov 2009
    Anaheim Hills, CA
    1,682
    Mazda 3 Sedan, Bc Coilcovers w/ removed collar in the fronts, MB Weapons 17x9 +27, 215/45/17, fenders rolled/shaved in the rear, driveable
  8. #8
    Nov 2009
    Anaheim Hills, CA
    1,682
    Mazdaspeed 3 09 HB, Eibach Sportlines, Rota G-Forces 18x8.5 +28 (Effectively with 20mm spacer - Front), 18x9 +30 (Rear), 215/45 (Front), 225/40 (Rear), Drivable, rolled fenders all around and cut where the bumper and fender meet in the rear, Rubs on dips.
  9. #9
    05 Mazda 3 HB , BC Coilovers, SSR Vienna Kreis 17x8 +29 F 17x9 R +37 Super Low Disk (clears rear stock brakes), 205/40/17 Delinte Thunder D7 Fronts / 215/40/17 Federal SS595 Rear. Rolled & Slightly pulled fenders. Driveable.
  10. #10
    '09 MS3
    Rota G-Force (18x9 /+30 offset)
    BC Coilovers and SPC Camber Arms
    F/R fenders rolled and rear tabs shaved
    Driveable and in need of m0ar l0w!
    COBB l HKS l FORGE l CP-E l STREET UNIT l BC l WFC #728
  11. #11
    Quote Originally Posted by shortwave View Post
    '09 MS3
    damn that looks good, im going for the same set-up but with a black speed 3. had the g-forces for awhile but i need coils.
    Stock
  12. #12
    Member supersaiyanms3's Avatar
    Dec 2010
    Seattle, WA.
    44
    '09 MS3
    Rota Boost 18x9 +30 offset with 205/40/18 Yokohama S-Drives
    BC Coilovers w/Extreme Drop Package
    Front: EDP Spring and Short Cartridges with two collars removed(one left). (-2 degrees camber)
    Rear:: EDP Spring with perch removed, SPC cambers arms maxed out. (-4 degrees camber)
    Front fenders rolled with a slight pull
    Rear fenders rolled with a slight pull rear bumper shaved where it meets with the fenders.
    Driveable w/ minimal rubbing.
    MS3Night by Evan Fujioka Photography, on Flickr
    New Stance3 by Evan Fujioka Photography, on Flickr
  13. #13
    Newcomer
    Jun 2011
    Columbus, Ohio
    11
    I absolutely love this car it looks perfect exactly what i want my red 3 to look like. I have an 05 m3s hatch red. If you know of any other tips or info you could give me besides whats written above the picture please let me know im going to order the springs and wheels soon with rear sway bar and camber. Also i guess the spacers are 20mm for front and whats for the rear??? 30?? thanks
  14. #14
    Nov 2009
    Anaheim Hills, CA
    1,682
    Quote Originally Posted by bcorrigan View Post
    What wheels are you talking about? If your getting new wheels you do not have to follow others mistakes on the offsets and run spacers. Instead get the correct offset.
  15. #15
    Newcomer
    Jun 2011
    Columbus, Ohio
    11
    Quote Originally Posted by SHaW View Post
    I want the rota gforce gold but i actually have a regular mazda 3 not speed three so the fenders arent as wide... i was looking at the red ms3 picture. i want 18" but 8.5 wide is cutting it close i realize i need to roll my fenders and not lower my car very much. what do you think like 45 or 48 offset?? thanks btw
  16. #16
    Newcomer
    Jun 2011
    Columbus, Ohio
    11
    also where the bumper and fender meet in the rear i have a bit of rust so if cutting out will help for fitments im all for it.
    What i found 18x8.5" 48 offset with fully adjustable camber on rear and ksport springs 1.3" drop all four. I noticed on the stock 17" their is little clearance for the rear trailing arms and front shocks/struts maybe and inch or so. My guy at discount tire says it might work. lol
  17. #17
    I am having a really hard time picking size/offset for my 09 ms3. I am on bc coilovers, sitting on the tires no finger gap. And i wanna keep it that low I was thinking 18x8 +45, will this be miserable to get to fit as low as it sits. I realize fender rolling will almost have to happen, but trying to avoid pulling/shaving etc. any info greatly appreciated, searched mad wheel threads and just cant decide
  18. #18
    Super Moderator lax22pearl's Avatar
    Apr 2011
    HI
    1,327
    easy. gonna need a roll but you gonna be sunk
  19. #19
    so what do you recommend for a flush/slight poke
  20. #20
    Apr 2011
    HI
    1,327
    18x9 +30. or even lower offset depending how much camber you want to have to run and how much of a stretch you want.
  21. #21
    Newcomer nwmotiv's Avatar
    Feb 2011
    Seattle
    13
    I might have the option very soon to run either 18x8 +35 (which is my current wheel spec and offset) or move up to 18x9 +36. I see that a lot of guys are starting to run 18x9 +30's, that gives them a little more room on the inner walls, is 6mm really that big of a deal?
  22. #22
    Regular
    Aug 2011
    IN
    170
    It's not that the 6mm makes a huge difference... more so people just trying to squeeze every last bit of wheel they possibly can. I just mounted up a 17x9 ET+48 on my gen 2 and it only has a credit card thickness between wheel and strut and still pokes past the fender just a hair. 18x9+35 would be perfect. With a tad of stretch, natural camber from the drop, and some very mild fender work, you should be set.
    2010 Mazda 3i Touring - Liquid Silver Metallic
    TRMotorsport's C3 17x9 ET(45/40)
    Kumho Ecsta LE Sport 235/45-R17
    Riceland Coilovers
  23. #23
    Regular OSSHWA's Avatar
    Nov 2010
    Northern VA
    369
    Damn Shavi.....your car has come a LONG way in the last year or so. From being lowered on springs/Rotas to being SLAMMED on coilovers/Rotiforms. Crazy!
    '05 Mazdaspeed MX-5/WFC #244
  24. #24
    Nov 2009
    Anaheim Hills, CA
    1,682
    Quote Originally Posted by OSSHWA View Post
    That was nearly two years ago though, back in Feburary 2010 lol
  25. #25
    Does anyone have pics of 18x8.5 +30? That what I'm thinking about running I just wanna see how it looks before I jump into it
    :edit on a gen1 mazdaspeed3
  26. #26
    Regular TrainWreck's Avatar
    Dec 2011
    Edmonds, WA
    181
    17x9's +30 with a 215/40/17 work with a little fender roll?
    Another knocker, kIck this game around like soccer!
  27. #27
    Addict XCNuse's Avatar
    Feb 2011
    Atlanta, GA
    686
    Some of the links are busted
    Anyone have any new or updated ones?
    This is a seriously helpful thread that needs to be kept alive!
    06 Whitewater Pearl build @ mazda3forums.com
  28. #28
    Nov 2009
    Anaheim Hills, CA
    1,682
    Quote Originally Posted by XCNuse View Post
    What links/parts? Everything I see looks the same.
  29. #29
    Feb 2011
    Atlanta, GA
    686
    Images; there are a few missing.
    After I posted I figured links was a bad word choice lol.
    I assume some are missing at least from some wording in a few posts.
    Either way.. A more expanded list will be much nicer than the few we have on here
  30. #30
    Nov 2009
    Anaheim Hills, CA
    1,682
    To me all the images are there.
    But, yeah I think people should start posting their individual setups, such as yours.
Tags for this Thread
