Results 1 to 5 of 5
Thread: How-To: Program spare/additional remotes for Mazda 3
    Newcomer Soy's Avatar
    Dec 2009
    San Clemente, CA
    41
    Default How-To: Program spare/additional remotes for Mazda 3
    Step 1: Open driver side door and leave open.
    Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
    Step 3: Insert key into the ignition.
    Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
    Step 5: Close and open the drivers door 3 times. Leave door open after this step
    Step 6: ECU should respond by locking and unlocking the doors once.
    Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
    Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
    Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
    Mods: Wingless, Badgeless, K&N Drop-In, Corksport Front Inserts, Forge BPV, Samco Hotpipe, Tokico Illumina Shocks and Springs, factory fresh Turbo and Exhaust Manifold.
    Nice!!
    2006 TG MZ3 - RIP*
    2010 BM MS3 - Cobb AP, Forge BPV, Denso Iridium ITV22, CP-E SRI, PG TIP, SU RMM, Res Delete, TP, NRG ETD, DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs, COBB shifter weight, ST Coilovers w/ Eibach rear Camber Kit(made by SPC) 18x8 +47 Drag DR34-black/time attack red lip, HKS TT Type 0, Clarion EQ, MB Quarts speakers, Pioneer Amp
    MAZFEST.COM
    Newcomer edwardthetwinky's Avatar
    Dec 2009
    Irvine, CA
    100
    If I do this.. do i need to "reprogram" all my other remotes with it?.. or does this apply to just adding a spare?
    Dec 2009
    San Clemente, CA
    41
    I'm not 100% sure, but I think any time you add a remote, you need to program all of them since it's a rotating code structure.
